Fehlermeldung beim Hochladen eines Bildes.
Discussion in 'Ihre Meinung zum Internetauftritt der PC-WELT' started by Shibby_89, Jun 23, 2004.
  1. Shibby_89
    Shibby_89 Halbes Megabyte
    Error Occurred While Processing Request
    An exception occurred when invoking an external process.
    The cause of this exception was that: java.io.IOException: java.io.IOException: /usr/bin/convert: not found.
    Please try the following:
    Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
    Check the ColdFusion documentation to verify that you are using the correct syntax.
    Search the Knowledge Base to find a solution to your problem.
    Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1)
    Remote Address 217.82.66.153
    Referrer
    Date/Time 23-Jun-04 03:08 PM
    Kann jemand helfen.
  2. Gerd-B
    Gerd-B Byte
    Nö :D
    Angeblich soll man's immer wieder versuchen bis es dann irgendwann funzzt.
    Soweit hab ich's aber auch noch nicht geschafft.
    gerd
