LG GSA-H22L Buffer-Problem
Discussion in 'Festplatten, SSD, USB-Sticks, CD/DVD/Blu-ray' started by indeli, Dec 10, 2006.
  1. indeli
    indeli ROM
    Hi!
    Problem: Mein LG GSA-H22L verweigert hartnäckig das Brennen von DVD's mit der Meldung "Buffer zu gross". Firmware laut LG-Firmware-Update auf neuestem Stand. "Normale" CD-Roms funktionieren auch problemlos. Kann jemand das Fehler-Log interpretieren???
    Gruß indeli
    Windows 2000 5.0
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Programme\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32
    NT-SPTI used
    Nero Version: 7.5.9.0
    Internal Version: 7, 5, 9, 0
    Recorder: <HL-DT-ST DVD-RAM GSA-H22L>Version: 1.00 - HA 1 TA 0 - 7.5.9.0
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <HL-DT-ST DVD-RAM GSA-H22L>Version: 1.00 - HA 1 TA 0 - 7.5.9.0
    === Scsi-Device-Map ===
    CdRomPeripheral : HL-DT-STDVD-RAM GSA-H22L1.00 viadsk Port 0 ID 1 DMA: Off
    DiskPeripheral : SAMSUNG SP0802N TK10 viadsk Port 1 ID 0 DMA: Off
    === CDRom-Device-Map ===
    HL-DT-ST DVD-RAM GSA-H22L E: CDRom0
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 57671680 (0) Byte
    BUFE : 0
    Physical memory : 383MB (392692kB)
    Free physical memory: 132MB (135384kB)
    Memory in use : 65 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    10.12.2006
    ISO Zusammenstellung
    11:32:39 #1 Text 0 File SCSIPTICommands.cpp, Line 411
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    11:32:39 #2 Text 0 File Isodoc.cpp, Line 6509
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : FALSE
    Multisession : TRUE
    Multisession type: : Start multisession
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    11:32:40 #3 ISO9660GEN -11 File Geniso.cpp, Line 3332
    First writeable address = 0 (0x00000000)
    11:32:40 #4 Text 0 File Burncd.cpp, Line 3451
    Turn on Disc-At-Once, using DVD media
    11:32:40 #5 Text 0 File DlgWaitCD.cpp, Line 306
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 534735 (118:49.60, 1044MB)
    11:32:40 #6 Text 0 File DlgWaitCD.cpp, Line 318
    Write in overburning mode: NO (enabled: CD)
    11:32:40 #7 Text 0 File DlgWaitCD.cpp, Line 2903
    Recorder: HL-DT-ST DVD-RAM GSA-H22L, Media type: DVD+R
    Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
    Disc Application Code: 0, Extended Information Indicators: 7
    11:32:40 #8 Text 0 File DlgWaitCD.cpp, Line 490
    >>> Protocol of DlgWaitCD activities: <<<
    11:32:40 #9 Text 0 File ThreadedTransferInterface.cpp, Line 821
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 534736 (534736) = #534736/118:49.61
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 534736 blocks [E: HL-DT-ST DVD-RAM GSA-H22L]
    11:32:40 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1024
    Prepare [E: HL-DT-ST DVD-RAM GSA-H22L] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc not fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1095139328, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 534736 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 534736 | 0 | 0x00
    534736 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    11:32:40 #11 Text 0 File SCSIPTICommands.cpp, Line 209
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    11:32:40 #12 Phase 36 File dlgbrnst.cpp, Line 1746
    Burn process started at 8x (11.080 KB/s)
    11:33:44 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2743
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    11:33:44 #14 Text 0 File Cdrdrv.cpp, Line 9234
    ---- DVD Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R (10), Part Version: 1.0x (1)
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 7 h
    Disc Manufacturer ID: MCC.....
    Media type ID: 004
    Number of Physical format information bytes in use in ADIP up to byte 63: 56
    Media Specific [16..63]:
    00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
    23 54 37 11 02 3C 6E 02 - 84 68 15 15 0B 0B 08 08 #T7..<n..h......
    01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
    11:33:44 #15 Text 0 File DVDPlusRW.cpp, Line 674
    Start write address at LBA 0
    DVD high compatibility mode: No
    11:33:45 #16 SPTI -31 File SCSIPassThrough.cpp, Line 179
    CdRom0: SCSIStatus(x00) WinError(87) NeroError(-31)
    Sense Key: 0x00 (KEY_NO_SENSE)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
    Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
    Buffer x080a0040: Len x10000
    0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    11:33:45 #17 SPTI -31 File SCSIPassThrough.cpp, Line 179
    Sense Code: 0x00
    Sense Qual: 0x00
    Buffer x06d69c40: Len x10000
    11:33:45 #18 Text 0 File MMC.cpp, Line 19912
    Writer-Buffer for E: HL-DT-ST DVD-RAM GSA-H22L reduced to 32768Bytes
    11:33:45 #19 SPTI -31 File SCSIPassThrough.cpp, Line 179
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 00 00 00 00 00 10 00 00 00
    Buffer x06d69c40: Len x8000
    11:33:45 #20 CDR -31 File Writer.cpp, Line 299
    Buffer too large
    11:33:45 #21 Phase 38 File dlgbrnst.cpp, Line 1746
    Burn process failed at 8x (11.080 KB/s)
    11:33:45 #22 Text 0 File SCSIPTICommands.cpp, Line 254
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    11:33:45 #23 Text 0 File Cdrdrv.cpp, Line 10467
    DriveLocker: UnLockVolume completed
    11:33:45 #24 Text 0 File SCSIPTICommands.cpp, Line 411
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    File 'Drivers\CDR4_2K.SYS': Ver=8.0.0.212 , size=2432 bytes, created 19.05.2006 22:16:24
    File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.05.2006 22:16:24
    File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 16.05.2006 21:23:54 (Prassi/Veritas driver for win 2K)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. JurTech
    JurTech Kbyte
    Wenn ich mich in dem Log-Wust nicht verlesen habe, läuft Dein H22L im PIO-Mode anstelle von UDMA.
    Ändere das erstmal und probiere es wieder.
    Ergebnis ggfls. hier posten.
    Oder/Und hast Du bei Nero 7.x dessen Buffergröße auf ein utopisches Maximum gestellt?
  3. indeli
    indeli ROM
    Danke für den Tipp!! :bet:
    Ich Depp hatte übersehen, dass im BIOS UDMA disabled war.
    Umgestellt-->ausprobiert-->Feuer frei-->Freude!!! :D
    Also Danke nochmal
    Indeli
