Mani Admin und die Souds
Discussion in 'Games für PC und Konsole' started by Godofkills, Sep 25, 2007.
  1. Godofkills
    Godofkills Byte
    also ich hab einen game server für css und da is auch mani druf jetzt hab ich auch sounds druf die ich und auch andere abspielen könne aber nur so "@ma_play cu" so dann hab ich im internet nachgeschaut und eine anleitung gesucht und gefunden und es so gemacht das es jeder abspielen kann aber es geht net :-(
  2. Godofkills
    Godofkills Byte
    die CFG:
    // Plugin : Mani Admin Plugin
    // Filename : mani_server.cfg
    // Last updated : 27/05/06
    // Desc : This is the core configuration file to turn on/off functionality
    // and to also config options within the plugin. By default the main
    // functions are turned off. For the most part the on/off switch is
    // usually the first cvar under each module (i.e mani_adverts,
    // mani_stats, etc)
    // In order for this config to be used by the plugin an exec command
    // must be placed in the server.cfg file within the /cfg folder.
    // 'exec mani_server.cfg'
    echo "****** Executing mani_server.cfg ******"
    // Module : Advert
    // Desc : Adverts can be used in game using this module in conjuction with the
    // adverts.txt file in the /cfg/mani_admin_plugin/ folder
    // Adverts 1 = on, 0 = off
    mani_adverts 0
    // Time between adverts displayed
    mani_time_between_adverts 120
    // Allow adverts in chat area of screen
    mani_adverts_chat_area 1
    // Allow adverts in top left corner of screen (these can be coloured)
    mani_adverts_top_left 1
    // Sets colour of adverts, here I've set it to blue
    // Red component colour of adverts (255 = max)
    mani_advert_col_red 0
    // Green component colour of adverts (255 = max)
    mani_advert_col_green 0
    // Blue component colour of adverts (255 = max)
    mani_advert_col_blue 255
    // Module : Stats
    // Desc : The stats module is a very simple ranking system based on 3 methods of
    // calculation (defined in mani_stats_calculate).
    // 1 = Enable stats module, 0 = disable stats module
    mani_stats 0
    // 0 = calculate once per map, 1 = calculate at end of each round (CSS Only)
    mani_stats_mode 1
    // Number of days since player last connected before they are removed from the
    // stats list
    mani_stats_drop_player_days 5
    // This cvar is used to set the type of stats calculation to use for ranking
    // players
    // 0 = Rank by by pure kills
    // 1 = Rank by by kill:death ratio
    // 2 = Rank by kills minus deaths
    mani_stats_calculate 2
    // Number of kills required before a player is given a rank
    // If you are using the Kill Death ratio you should set this quite high
    mani_stats_kills_required 0
    // Defines how long a 'top' display lasts for before it fades (5 - 30 seconds)
    mani_stats_top_display_time 10
    // Defines whether other players see your rank when you type 'rank'
    // 1 = show rank to all players
    // 0 = only show rank to player who typed 'rank'
    mani_stats_show_rank_to_all 1
    // Defines a message to show when a user types 'rank' and the stats are turned
    // off (this can be blank)
    mani_stats_alternative_rank_message "www.mystats.com"
    // Enables writing of ranks to a text file called mani_ranks.txt for export to a
    // web page.
    mani_stats_write_text_file 1
    // Set in minutes how often you want the stats save,
    // 0 = only once per map change. This should be used when you play
    // one map 24/7 with no timelimit
    mani_stats_write_to_disk_frequency 0
    // Set to 1 if you want your ranks to be by steam id (default),
    // Set to 0 if you are not using steam ids on your server (Lan mode)
    mani_stats_by_steam_id 1
    // 1 = Include any bot kills made in stats
    // 0 = Killing a bot does not count to stats
    mani_stats_include_bot_kills 0
    // Module : Victim Stats
    // Desc : The victim stats module shows your statistic for the period when
    // you were alive
    // Allow the use of victim stats
    // 0 = off
    // 1 = on
    mani_show_victim_stats 0
    // Set to 1 if you don't want to see damage taken from yourself
    mani_show_victim_stats_inflicted_only 0
    // This controls the default mode a player will have their victim stats mode
    // set to when they first ever join your server. This setting is applied to
    // the player's stored record withing player_settings.dat it does not control
    // whether the victim stats functionality is on or off.
    // 0 = mode 0, 1 = mode 1, 2 = mode 2
    mani_player_settings_damage 0
    // Module : Team Kill/Wound Protection
    // Enable TK Protection 1 = on, 0 = off
    mani_tk_protection 0
    // Enable TK Punishment menu 1 = on, 0 = off
    mani_tk_forgive 1
    // Time allowed after freezetime where spawn protection is enabled
    mani_tk_spawn_time 5
    // Defines whether bots can run tk punish options on other player (1 = on)
    mani_tk_allow_bots_to_punish 1
    // Defines whether when tk'ing a bot adds to a players tk violation count
    // 0 = off, 1 = on
    mani_tk_allow_bots_to_add_violations 0
    // Number of tk violations before player is banned
    mani_tk_offences_for_ban 7
    // Time in minutes for a tk ban, 0 = permanent
    mani_tk_ban_time 5
    // When set to 1 a player will be slapped and have their view moved when
    // team wounding.
    mani_tk_slap_on_team_wound 0
    // Sets the amount of damage a team wound inflicts on the attacker
    mani_tk_slap_on_team_wound_damage 0
    // If set to 1 shows opposition team wounds in chat and all team wounds if
    // you are spectator, 0 = normal css style
    mani_tk_show_opposite_team_wound 1
    // Defines whether a players tk violation count is incremented even if
    // forgiven (0 = off, 1 = on)
    mani_tk_add_violation_without_forgive 0
    // Turn on forgive option for tk punishments
    mani_tk_allow_forgive_option 1
    // Defines whether the blind option can be used on players (1 = on)
    mani_tk_allow_blind_option 1
    // Amount of blindness for 'blind' punishment (255 = completely blind)
    mani_tk_blind_amount 253
    // Turn on slap option for tk punishments
    mani_tk_allow_slap_option 1
    // Turn on tk cash option for tk punishments
    mani_tk_allow_cash_option 1
    // Amount of health that a player will slapped to
    mani_tk_slap_to_damage 10
    // Amount of cash to take from a team killer
    mani_tk_cash_percent 30
    // Turn on freeze option for tk punishments
    mani_tk_allow_freeze_option 1
    // When set to 1 the Drug option is allowed in the TK Menu
    mani_tk_allow_drugged_option 1
    // Turn on burn option for tk punishments
    mani_tk_allow_burn_option 1
    // This defines how long the burn time should be for in seconds for a
    // tk punishment
    mani_tk_burn_time 100
    // Turn on slay option for tk punishments
    // 1 = on, 0 = off
    mani_tk_allow_slay_option 1
    // Main option to turn on damage reflection
    // 1 = on, 0 = off
    mani_tk_team_wound_reflect 0
    // Set the number of team wounds required by a player during the course
    // of a map before the reflective damage kicks in
    mani_tk_team_wound_reflect_threshold 5
    // This value is a damage multiplier that inflicts whatever damage
    // (armor loss + health loss) was given to the victim back to the attacker.
    // When set to 1.0 the damage is perfectly reflected, set at 2.0
    // the damage inflicted back on the attacker will be twice the damage etc.
    mani_tk_team_wound_reflect_ratio 1.0
    // An addition cvar here increases the reflection ratio each time the player
    // teamwounds another player. This is to deter persistent team wounders
    mani_tk_team_wound_reflect_ratio_increase 0.1
    // This defines whether the tk time bomb option can be used or not
    mani_tk_allow_time_bomb_option 1
    // This defines the time before the bomb goes off
    mani_tk_time_bomb_seconds 10
    // This defines the bomb blast radius
    mani_tk_time_bomb_blast_radius 1000
    // 0 = no beams, 1 = beams on
    mani_tk_time_bomb_show_beams 1
    // 0 = player only, 1 = players on same team, 2 = all players
    mani_tk_time_bomb_blast_mode 2
    // This defines whether the tk fire bomb option can be used or not
    mani_tk_allow_fire_bomb_option 1
    mani_tk_fire_bomb_seconds 10
    mani_tk_fire_bomb_blast_radius 1000
    mani_tk_fire_bomb_show_beams 1
    mani_tk_fire_bomb_blast_mode 2
    // Time in seconds that players will burn for
    mani_tk_fire_bomb_burn_time 100
    // This defines whether the tk freeze bomb option can be used or not
    mani_tk_allow_freeze_bomb_option 1
    mani_tk_freeze_bomb_seconds 10
    mani_tk_freeze_bomb_blast_radius 1000
    mani_tk_freeze_bomb_show_beams 1
    mani_tk_freeze_bomb_blast_mode 2
    // Radius of beep circle, 0 = radius measures the same as the bomb blast,
    // default is 256
    mani_tk_time_bomb_beep_radius 0
    // default is 256
    mani_tk_fire_bomb_beep_radius 0
    // default is 256
    mani_tk_freeze_bomb_beep_radius 0
    // Allow TK Beacon circle tk option
    mani_tk_allow_beacon_option 1
    // Radius of beacon circle
    mani_tk_beacon_radius 384
    // Module : Reserve Slot
    // Desc : The Reserve slot module configuration cvars
    // Turn on off reserve slots
    mani_reserve_slots 0
    // Number of reserve slots you have
    mani_reserve_slots_number_of_slots 1
    // User defined message shown in players console when kicked
    mani_reserve_slots_kick_message "You were disconnected for using a reserve slot"
    // User defined message for redirection of players to another server
    mani_reserve_slots_redirect_message "This server is full, you are being redirected to another one of our servers"
    // The IP address of the server you wish to redirect players to. Leave it blank
    // if you do not want redirection to be used
    mani_reserve_slots_redirect ""
    // This defines whether you want your reserve slots to fill with reserve players
    // or always be kept free (1 = allow slots to fill, 0 = always keeps slots free
    // and kick player instead)
    mani_reserve_slots_allow_slot_fill 1
    // Type of method used to kick players, 0 = by highest ping (spectators first),
    // 1 = by connection time (spectators go first)
    mani_reserve_slots_kick_method 1
    // Include admins in the adminlist.txt file as players who have reserve slots
    // (1 = include admins)
    mani_reserve_slots_include_admin 1
    // Module : High Ping kick
    // Enable disable high ping kicker (1 = on)
    mani_high_ping_kick 0
    // Set the ping at which you want players kicked
    mani_high_ping_kick_ping_limit 400
    // Number of samples and averaged before a decision is made to kick a player
    // (1 sample is about 1.5 seconds)
    mani_high_ping_kick_samples_required 60
    // Message displayed in console when player is disconnected
    mani_high_ping_kick_message "Your ping is too high"
    // Module : Admin action messages
    // Desc : This section defines which admin actions will be anonymous to
    // non-admins on your server. If the option is set to 1 then the action
    // will not be shown to non-admins, if set to 0 then all players will
    // see which admin kicked/slayed/banned/etc a player.
    mani_adminslap_anonymous 1
    mani_adminblind_anonymous 1
    mani_adminfreeze_anonymous 1
    mani_adminteleport_anonymous 1
    mani_admindrug_anonymous 1
    mani_adminmap_anonymous 1
    mani_adminswap_anonymous 1
    mani_admingimp_anonymous 1
    mani_adminvote_anonymous 1
    mani_adminsay_anonymous 1
    mani_adminkick_anonymous 1
    mani_adminslay_anonymous 1
    mani_adminban_anonymous 1
    mani_adminburn_anonymous 1
    mani_adminnoclip_anonymous 1
    mani_adminmute_anonymous 1
    mani_admincash_anonymous 1
    mani_adminsetskin_anonymous 1
    mani_admindropc4_anonymous 1
    mani_admintimebomb_anonymous 1
    mani_adminfirebomb_anonymous 1
    mani_adminfreezebomb_anonymous 1
    mani_adminhealth_anonymous 1
    mani_adminbeacon_anonymous 1
    mani_admingravity_anonymous 1
    // Module : Chat flooding control
    // Desc : This is to control chat spam with the game
    // Sets the time threshold for chat spamming (0 = off, 1.5 is a good
    // value for use)
    mani_chat_flood_time 0
    // Sets the message the player will receive when they are spamming
    mani_chat_flood_message "STOP SPAMMING THE SERVER !!"
    // Module : Basic auto balance teams
    // Desc : This is a very basic auto balancer, this does not take into
    // account player skill
    // Set to 1 for auto team balancing at end of rounds (an alternative to the
    // CSSource built in team balancer)
    mani_autobalance_teams 0
    // 0 = Players balanced regardless if dead or alive, 1 = dead players swapped
    // first followed by alive players, 2 = only dead players can be swapped
    mani_autobalance_mode 1
    // Module : Current Time Display
    // Desc : This controls the time of day message formatting
    // 1 for military style time, 0 for 12 hour clock
    mani_military_time 1
    // Set to your servers timezone or leave it blank, it will be added to the
    // end of the time when displayed
    mani_thetime_timezone "GMT"
    // mani_adjust_time cvar allows you to specify the number of minutes to
    // add or subtract from your server clock when you type thetime in game.
    // If you server is 20 minutes fast set mani_adjust_time -20, if it is
    // 30 minutes slow set mani_adjust_time 30.
    mani_adjust_time 0
    // Module : Gimping
    // Desc : This controls the messages displayed when a player is gimped and
    // un-gimped
    // Message displayed when a player is gimped
    mani_gimp_transform_message "Everyone point and laugh at the Gimp!"
    // Message displayed when a player is un-gimped
    mani_gimp_untransform_message "The gods are merciful, The Gimp is back to normal"
    // Module : Voting functionality
    // Desc : There are two types of vote. System started where an admin has
    // triggered a vote or User started where a user has started a vote
    // The following cvars control the configuration of the voting
    // Allow voting 1 = on, 0 = off (this cvar controls ALL voting)
    mani_voting 0
    // Defines the last number of maps played to not show in random votemap lists
    mani_vote_dont_show_last_maps 3
    // Defines the time in minutes a extend vote will add to the timeleft counter
    mani_vote_extend_time 20
    // Defines the whether the a map can be extended
    mani_vote_allow_extend 1
    // Defines amount of time in seconds a vote will be allowed for
    mani_vote_allowed_voting_time 45
    // Defines whether a random map vote will be displayed towards the end of
    // the map
    mani_vote_allow_end_of_map_vote 0
    // Number of extensions a map is allowed via user vote or random map vote,
    // 0 = infinite
    mani_vote_max_extends 2
    // Number of rounds to extend by if mp_winlimit is not 0
    mani_vote_extend_rounds 10
    // Define the file to use for random map vote
    // 0 = mapcycle.txt, 1 = votemapslist.txt, 2 = maplist.txt
    mani_vote_mapcycle_mode_for_random_map_vote 0
    // Define the file that admin can select from for admin
    // started vote.
    mani_vote_mapcycle_mode_for_admin_map_vote 0
    // Defines how many minutes before the end of the map that a random map vote
    // is started
    mani_vote_time_before_end_of_map_vote 3
    // Defines how many maps can be in the end of map vote
    mani_vote_max_maps_for_end_of_map_vote 6
    // Defines the vote percentage required to set map
    mani_vote_end_of_map_percent_required 60
    // Defines the vote percentage required to set rcon vote
    mani_vote_rcon_percent_required 60
    // Defines the vote percentage required to set question vote
    mani_vote_question_percent_required 60
    // Defines the vote percentage required to set map vote
    mani_vote_map_percent_required 60
    // Defines the vote percentage required to set random map vote
    mani_vote_random_map_percent_required 60
    // This cvar determines how the players see the votes during voting
    // 0 = quiet mode,
    // 1 = show players as they vote but not their choice,
    // 2 = Show voted choice but not player,
    // 3 = show player name and their choice
    mani_vote_show_vote_mode 3
    // Following cvar now has 2 modes of operation
    // 0 = alive players will see vote menu,
    // 1 = alive players will need to type vote to access the menu,
    mani_vote_dont_show_if_alive 0
    // Allow user started votemaps
    mani_vote_allow_user_vote_map 0
    // Allow the users to extend maps if time based
    mani_vote_allow_user_vote_map_extend 1
    // Allow the users to kick players by vote
    mani_vote_allow_user_vote_kick 0
    // Allow the users to ban players by vote
    mani_vote_allow_user_vote_ban 0
    // Defines the vote percentage required to set an extend map vote
    mani_vote_extend_percent_required 60
    // Percentage of votes required from players before map change
    mani_vote_user_vote_map_percentage 60
    // Time after a new map starts that voting is allowed
    mani_vote_user_vote_map_time_before_vote 60
    // Minimum number of votes required to change a map (override vote percentage)
    mani_vote_user_vote_map_minimum_votes 4
    // 0 = only when no admin on server, 1 = all the time
    mani_vote_user_vote_kick_mode 0
    // Percentage of votes required from players before kick occurs
    mani_vote_user_vote_kick_percentage 60
    mani_vote_user_vote_kick_time_before_vote 60
    // Minimum number of votes required (override vote percentage)
    mani_vote_user_vote_kick_minimum_votes 4
    mani_vote_user_vote_ban_mode 0
    mani_vote_user_vote_ban_percentage 60
    mani_vote_user_vote_ban_time_before_vote 60
    mani_vote_user_vote_ban_minimum_votes 4
    // Time in minutes for the ban, 0 = permanent ban
    mani_vote_user_vote_ban_time 30
    // 0 = ban by ID, 1 = ban by IP, 2 = ban by ID and IP
    mani_vote_user_vote_ban_type 0
    // Allow rock the vote
    mani_vote_allow_rock_the_vote 1
    mani_vote_rock_the_vote_percent_required 60
    // Time before rockthevote can be started after a new map starts
    mani_vote_time_before_rock_the_vote 120
    // Number of nominations included in the vote
    mani_vote_rock_the_vote_number_of_nominations 4
    // Number of random maps chosen from votemaplist.txt
    mani_vote_rock_the_vote_number_of_maps 8
    // Percentage of players on server required to type rockthevote before
    // it starts
    mani_vote_rock_the_vote_threshold_percent 60
    // Minimum number of players required to type rockthevote before it starts
    mani_vote_rock_the_vote_threshold_minimum 4
    // This controls the default mode a player will have their 'show vote progress'
    // whether the death beam functionality is on or off.
    // 0 = player settings default to off, 1 = player settings default to on
    // 1 = default on, 0 = default off
    mani_player_settings_vote_progress 1
    // Module : Word filter module
    // Desc : The following cvars control the configuration of the chat word filter
    // 0 = off, 1 = show warning to player, 2 = show filtered text
    mani_filter_words_mode 1
    // Message shown to player
    mani_filter_words_warning "Hör auf zu beleidigen(STOP with this words!!)"
    // Module : Sounds Control
    // Desc : The following cvars control how system sounds are configured. This
    // is not related to the Quake sounds
    // Set to the number of sounds you wish a regular non-admin player to be able
    // to use per round
    mani_sounds_per_round 3
    // Set to 1 if you want alive players not to hear sounds triggered by dead
    // players
    mani_sounds_filter_if_dead 0
    // mani_sounds_auto_download is a cvar to control whether server sounds
    // (not quake sounds) are auto downloaded to a client. If set to 0 you must
    // provide your own .res files to initiate transfers to a client.
    // If you change this value from 1 to 0 while the server is running you
    // must restart your server.
    mani_sounds_auto_download 1
    // This controls the default mode a player will have their death beam mode
    mani_player_settings_sounds 1
    // Module : Plugin Logging
    // Desc : The following cvars control how the plugin logging is configured
    // Admin logging parameters
    // Directory where logs will be stored under the mani_path directory
    // The logging mode you wish to use
    // 0 = default placing of log files in the same .log files that Valve creates
    // 1 = logs created per map change using the same style filenames that Valve
    // uses in the mani_log_directory directory
    // 2 = One large file is written in the mani_log_directory
    // 3 = A log is written as a steam id for each admin that runs a command, the
    // format is STEAM_x_x_xxxxxxxx.log
    mani_log_mode 0
    // Path where the logs are stored
    mani_log_directory "mani_logs"
    // Module : Death Beams
    // Desc : The death beams show a solid beam when you die between the point
    // where your attacker killed you from and the point where you
    // were when you died. Only the victim will see the beam
    // 0 = death beams not allowed, 1 = death beams are shown if player
    // has them turned in their settings
    mani_show_death_beams 0
    mani_player_settings_death_beam 1
    // Module : Anti IP Ghosting
    // Desc : The plugin can be configured to blind players on the same IP once
    // they die and another player is still alive. At the point when all
    // players ghosting on the same IP are dead they will be able to see
    // again.
    // This cvar prevents players on the same IP from viewing the game whilst
    // another player on the same IP is still alive. Admins on the same IP are
    // immune from this and there is an immunity flag that can also be used.
    // 0 = Dont blind ghosters on same IP, 1 = blind ghosters on same IP address
    mani_blind_ghosters 0
    // The following cvars can prevent players using the same IP taking over
    // your server by having a majority vote and kicking players so they can play.
    // 0 = Players on same IPs cannot use voteban
    // 1 = Players on same IPs can use voteban
    mani_vote_allow_user_vote_ban_ghost 1
    // 0 = Players on same IPs cannot use votekick
    // 1 = Players on same IPs can use votekick
    mani_vote_allow_user_vote_kick_ghost 1
    // Module : Decal Map Adverts
    // Desc : In game map adverts can be placed onto static objects in the game
    // such as walls.
    // 1 = turn on map adverts, 0 = turn off map adverts
    mani_map_adverts 0
    // Note about the following cvar. If you enable war mode with
    // mani_map_adverts_in_war 0 then you must either change map or get the
    // players to type 'retry' in their console for the existing adverts to disappear
    // 1 = allow map adverts with war mode on
    // 0 = disallow map adverts in war mode
    // Module : Anti-cheat
    // Desc : For the most part this code is now out of date as Vac should pick
    // up the cheat type that this looks for so it is not worth turning on
    // the detection at the current time.
    // 1 = enable cheat detection
    // 0 = disable cheat detection
    mani_protect_against_cheat_cvars 0
    // Set number of cheat detections required before action is taken
    mani_protect_against_cheat_cvars_threshold 5
    // 0 = Ban by Steam ID, 1 = Ban by IP, 2 = Ban by Steam and IP
    mani_protect_against_cheat_cvars_mode 0
    // 0 = permanent ban otherwise specifies the number of minutes
    mani_protect_against_cheat_cvars_ban_time 0
    // 0 = off otherwise set to the number of name changes allowed before
    // action is taken (this was for a hack that constantly changed a player's
    // name making it hard to find the actual player to ban)
    mani_player_name_change_threshold 15
    // 0 = reset name change count per round
    // 1 = reset name change count per map
    mani_player_name_change_reset 0
    // 0 = kick, 1 = ban by ID, 2 = ban by IP, 3 = ban by ID and IP
    mani_player_name_change_punishment 0
    mani_player_name_change_ban_time 0
    // Module : Custom Skin Control
    // Desc : The following cvars are used to configure the options for the skins
    // 0 = Dont allow admins to have admin skins, 1 = Allow admins to have admin
    // skins
    mani_skins_admin 1
    // 0 = Dont allow public skins for normal players, 1 = Allow public skins
    // for normal players
    mani_skins_public 0
    // 0 = Dont force first skin in list for public player, 1 = Force first skin
    // in list on public player
    mani_skins_force_public 0
    // 0 = Allow all skins to be selected via ma_setskin, 1 = Only allow misc
    // skins to be used
    mani_skins_setskin_misc_only 0
    // 0 = Dont auto download skin resources, 1 = auto download skin resources
    // to clients
    mani_skins_auto_download 0
    // 0 = Dont allow immunity players to have reserved skins,
    // 1 = Allow immunity players to have reserved skins
    mani_skins_reserved 0
    // 0 = No menu on team join, 1 = show skin chooser on team join,
    // 2 = show settings menu on team join
    mani_skins_force_choose_on_join 1
    // 0 = no custom skins for bots, 1 = use random public class skins on bots
    mani_skins_random_bot_skins 1
    // Module : Spray Tag Tracking
    // Desc : The spray tag tracking module allows an admin to check the details
    // of who sprayed a tag within the game using the command ma_spray
    // while near the spray in question
    // Spray Tag Tracking control
    // 0 = off, 1 = on
    mani_spray_tag 0
    // Time in seconds that a spray will be tracked for
    mani_spray_tag_spray_duration 120
    // Max distance away from a spray that you can be for acquisition
    mani_spray_tag_spray_distance_limit 500
    // Use effect to show which spray is being targetted
    // 0 = none
    // 1 = beam (defaults to glow for DoD)
    // 2 = glow
    mani_spray_tag_spray_highlight 1
    // Non-permanent ban time in minutes
    mani_spray_tag_ban_time 60
    // Console messages
    mani_spray_tag_warning_message "Please stop using your spray"
    mani_spray_tag_kick_message "You have been kicked for using an offensive spray"
    mani_spray_tag_ban_message "You have been banned for 60 minutes through using an offensive spray"
    mani_spray_tag_perm_ban_message "You have been permanently banned for using an offensive spray"
    // 0 = Allow sprays on the server
    // 1 = Block all sprays on the server (must have mani_spray_tag 1)
    mani_spray_tag_block_mode 0
    // Warning message if sprays are blocked
    mani_spray_tag_block_message "Sprays are blocked on this server !!"
    // Amount of damage to inflict for a spray tag warn with slap option
    mani_spray_tag_slap_damage 0
    // Module : Warmup Timer
    // Desc : Warmup timers are used at the start of a map. A timer can be setup
    // that will restart the map after a set amount of time. For something
    // like CSS this means late joiners can still start on the pistol round
    // and not miss out.
    // 0 = No warmup time on map load
    // Greater than 0 = number of seconds after map load until map restarts and
    // play continues as normal.
    mani_warmup_timer 0
    // 1 = visible countdown displayed in center of screen
    // 0 = no countdown displayed
    mani_warmup_timer_show_countdown 1
    // Module : Menu options
    // Desc : The following options determine the type of menu you wish to use
    // and how they are displayed
    // Set to 1 for in game amx style menus, or 0 for Escape style menus
    // This is overriden by the gametypes.txt file if the game does not support
    // AMX style menus. At the time of writing there are only 3 games that support
    // the AMX style. CS:S, DoD:S and HL2CTF
    mani_use_amx_style_menu 1
    // 0 = No sorting of menus, 1 = Sort most menus by players name
    mani_sort_menus 1
    // Module : Miscallaneous
    // Desc : Small cvars for various controls
    // Call to the mani_quake_sounds.cfg file if it exists
    exec mani_quake_sounds.cfg
    // The following cvar controls how the mapcycle is calculated
    // 0 = standard Valve map cycle,
    // 1 = if you don't want your mapcycle to reset to the first in the
    // list when moving to a map not in the cycle,
    // 2 = random cycle (uses mani_vote_dont_show_last_maps cvar to exclude
    // last maps played)
    // 3 = skip to the next unplayed map in the map cycle list until all maps
    // have been played when it is reset.
    mani_mapcycle_mode 0
    // 0 = Normal game play
    // 1 = players get free HEs in CSS at spawn and after an HE has been thrown
    mani_unlimited_grenades 0
    // Force all dead players to run overview_mode 0 every game frame
    mani_war_mode_force_overview_zero 0
    // Set this to allow stacking of players in CSS
    // (overrides cs_stacking_num_levels cvar)
    mani_cs_stacking_num_levels 2
    // mani_use_ma_in_say_command When set to 1 you must use the prefix ma_ in
    // say commands, if 0 you can drop the ma_ prefix if you wish
    // This is only for in game say commands and for Beetlefart compatibilty if
    // you use it.
    mani_use_ma_in_say_command 0
    // 0 = All Dead talk off, 1 = All dead talk on
    mani_dead_alltalk 0
    // Set to 0 for normal mode, set to 1 for spam removal.
    // This cvar is useful if you are using Mattie's Event Scripts that call
    // plugin functions so the chat area is not spammed.
    mani_mute_con_command_spam 0
    // Enable disable top left ma_say and ma_chat
    mani_adminsay_top_left 1
    // Enable disable chat area ma_say and ma_chat
    mani_adminsay_chat_area 1
    // Allow users to chat to admins using ma_chat
    mani_allow_chat_to_admin 1
    // Defines whether the command ff executed is shown only to the player or the
    // whole server (1 = player only)
    mani_ff_player_only 0
    // Defines whether the command nextmap executed is shown only to the player or
    // the whole server (1 = player only)
    mani_nextmap_player_only 0
    // Defines whether the command timeleft executed is shown only to the player
    // or the whole server (1 = player only)
    mani_timeleft_player_only 0
    // Defines whether the command thetime executed is shown only to the player or
    mani_thetime_player_only 0
    // This defines how long the burn time should be for in seconds when a player
    // is burned by admin
    mani_admin_burn_time 20
    // Finish up with a message to the console
    echo "****** Finished executing mani_server.cfg ******"
  3. Godofkills
    Godofkills Byte
    COMANDLIST:
    // Mani Admin Plugin 2005
    // file : commandlist.txt
    // This file allows you to change the in game say commands
    // by replacing them with your own version.
    // The format is "yourcommand" type replacement command
    // The type refers to either: -
    // R = an RCON command to be executed (User must be admin with RCONSay
    // authorisation
    // An example would be: -
    // "@botadd" R bot_add
    // "@alltalk" R sv_alltalk 1
    // "@rr" R mp_restartgame 2
    // C = run a client command on your machine, anyone can use these
    // "@menu" C admin
    // "@vote" C say votemap
    // "@kickmenu" C admin kick
    // S = replace an @say command with your own version
    // "@torch" S @ma_burn
    // "@kill" S @ma_slay
    // Note that comments must be started on a new line
    // Do not do "@botadd" R bot_add // command to add bots
    "@botadd" R bot_add
    "@menu" C admin
    "@torch" S @ma_burn
    "@kill" S @ma_slay
    "cu" C ma_play cu; say öhi
