Wodurch unterscheiden sich diese CPUs?
Discussion in 'CPU, BIOS & Motherboards, RAM' started by Thomania, Nov 14, 2008.
  1. Thomania
    Thomania Kbyte
  2. vtr1000
    vtr1000 Kbyte
    Der E0 geht mit unseren Ressourcen (Strom) etwas genügsamer um. Hier mal die Beschreibung:
    Enhanced Intel® Deeper Sleep with Dynamic Cache Sizing
    This new power savings mechanism flushes system memory dynamically, based on demand or during periods of inactivity. Power savings occur as the cache ways are turned off once the data has been saved in memory. Because L2 cache data integrity determines Deeper Sleep minimum voltage limits for the Intel Core Duo processor, once the Dynamic Cache Sizing feature flushes the entire L2 cache to memory, the processor transitions to a new power management state. This is called Enhanced Intel® Deeper Sleep, and allows the processor to lower voltage below the Deeper Sleep minimum voltage for enhanced power savings and/or efficiencies.
  3. ASimon
    ASimon Kbyte
    daher mit E0 stepping=bessere wahl
